Heyho,
Question 1: I want to change the type (for example (f.e.): http://transphoto.ru/vehicle/125164/), because (f.e.) 222 171 is a T4D and 224 513 is a T4D-MI, but I change them in the database and it change all
Question 2: When a user changes/add a record, how can I add that? So how do I add the record to the database?
Thanks for Help..
Nico (Tatra-Fan)
Vehicle-list: How to change type? How add a record?
To get an ability to specify types separately for each number, you should mark the following checkbox: http://s011.radikal.ru/i315/1012/43/3ab15dd0aa86.jpg («указывать модель/заводской №/дату постройки отдельно для каждого номера»).Tatra-Fan пишет:Question 1: I want to change the type (for example (f.e.): http://transphoto.ru/vehicle/125164/), because (f.e.) 222 171 is a T4D and 224 513 is a T4D-MI, but I change them in the database and it change all
You will see list of these records on page «Пользовательский ПС». By following the links in the most left column, you will move to the «Add Vehicle» page (if user has made an addition) or to the «Edit Vehicle» page (if user has made correction). If it is an addition, then form will be filled with user's data, so you need to check it and click «Отправить» («Send») button. If it is a correction, then under the form you will see table with user's data. You can copy fields to the main form by clicking on its names in the user's data table. When all needed data will be copied, you shoud click «Информация учтена, удалить данные» link («Information is received, remove user's record») and then click «Отправить» («Send») button.Tatra-Fan пишет:Question 2: When a user changes/add a record, how can I add that? So how do I add the record to the database?
