Denmark - Tramway under construction
This forum is for non-Russian-speaking users of our website. You can write here in any language.
Christian Maibaum
Сообщение Christian Maibaum » 05 июн 2017, 18:36
The Country of Denmark needs some editing: http://transphoto.ru/region.php?rid=62
There are two new tramway systems under construction:
In addition there is a Hovedstadens Letbane (Kopenhagen / København Ring 3 Light rail) planned to open in 2020 but not jet under construction.
As the cities of Århus and Odense are already part of the database (because they once had a tram), both cities need a new tram facility.
Михаил Исаков
Сообщение Михаил Исаков » 06 июн 2017, 19:33
Christian Maibaum пишет:
05 июн 2017, 18:36
Both have been added. Thanks!
Christian Maibaum
Сообщение Christian Maibaum » 06 июн 2017, 21:24
06 июн 2017, 19:33
05 июн 2017, 18:36
Thanks for the edit.
Could you rename the new facilities to "Letbane" (or Aarhus Letbane and Odense Letbane) instead of "Tramway"? Letbane is the Danish word for "Light rail".
Both cities will use low floor tramcars (Stadler Variobahn), not light rail vehicles.
Christian Maibaum
Сообщение Christian Maibaum » 06 июн 2017, 21:30
Please add a tramway Museum to Manchester (Great Britain):
Heaton Park Tramway
Please use "Heaton Park Tramway" as title, not "Museum" or "Tramway Museum".
Thank You :good:
Михаил Исаков
Сообщение Михаил Исаков » 07 июн 2017, 11:48
Both are done.
Christian Maibaum
Сообщение Christian Maibaum » 03 июл 2017, 21:24
I have news from China that requires a change to the database.
http://www.metro-report.com/news/news-b ... nzhen.html
https://www.skyscrapercity.com/showthre ... =140958346
The tramcars are made by CRRC Zhuzhou (2015 renamed from CSR Zhuzhou). The vehicles have no model name, although they correspond to the Siemens Avenio, which CRRC Zhuzhou was allowed to build under license.
- > please add to the database.
Please add the Cities / tram active:
  • Huai'an
  • Nanjing "Hexi Tram"
  • Nanjing "Qilin Tram"
  • Shenzhen
  • Suzhou
  • Wuhan
Nanjing has two independent tram lines - "Hexi Tram" and "Qilin Tram". Therefore, Nanjing needs two depots.
Christian Maibaum
Сообщение Christian Maibaum » 14 июл 2017, 09:40
The city of Luxembourg needs some editing.
It needs a new tram facility / operator under construction:
  • Luxtram
source: http://www.metro-report.com/news/light- ... nning.html
Михаил Исаков
Сообщение Михаил Исаков » 14 июл 2017, 12:59
03 июл 2017, 21:24
  • Huai'an
  • Shenzhen
  • Suzhou
  • Wuhan
Are they all already in operation?
Christian Maibaum
Сообщение Christian Maibaum » 14 июл 2017, 19:44
14 июл 2017, 12:59
Yes, all in operation.
Михаил Исаков
Сообщение Михаил Исаков » 16 июл 2017, 07:46
14 июл 2017, 19:44
14 июл 2017, 12:59
I've added all cities. Anything else required?
Christian Maibaum
Сообщение Christian Maibaum » 16 июл 2017, 20:56
16 июл 2017, 07:46
Yes :D
Please change the default facility for the city Leipzig in the "edit database" http://transphoto.ru/lk/vehicles.php?action=add
from "Historischer Straßenbahnhof Leipzig-Möckern" to "Leipziger Verkehrsbetriebe".
Михаил Исаков
Сообщение Михаил Исаков » 17 июл 2017, 04:17
16 июл 2017, 20:56
16 июл 2017, 07:46
Yes :D
Not sure what you mean by "default facility". Can you please explain more detailed? Screnshot would be the best.
